I was putting together a PC on pcpartpciker and this came up when I finished:
"The Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory operating voltage of 1.45 V exceeds the AMD Zen 2 CPU recommended maximum of 1.35 V+7% (1.444 V). This memory module may run at a reduced clock rate to meet the 1.35 V voltage recommendation, or may require running at a voltage greater than the AMD recommended maximum."
The CAS latency is 14 and timing is 14-16-16-36.
The CPU is Ryzen 7 3700x.
What should I do? Keep the ram or change it?
https://linustechtips.com/topic/1163996-memory-voltage-problem/
That's odd - my 3600mhz kit is at 1.35v - I didn't know of any consumer DDR4 kits that operate higher than 1.35v within the XMP/DOCP profile.
Following to figure this out
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1163996-memory-voltage-problem/#findComment-13365759
