Evga or cooler master?
Go to solution Solved by Slottr,
Don't base it around brand, base it around model. They both have good and bad units- both of those being mediocre.
Reference our power supply tier list:
Look for something around 550w. If you're budgeted, the CX units from corsair are fair.
https://linustechtips.com/topic/1163733-evga-or-cooler-master/#findComment-13363250
both are bad units.
grab a CX or something better.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1163733-evga-or-cooler-master/#findComment-13363266
Ok, thanks. Cx550 (not modular) is only 2€ more than the evga
https://linustechtips.com/topic/1163733-evga-or-cooler-master/#findComment-13363275
and it's much better in quality
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1163733-evga-or-cooler-master/#findComment-13363282
