i'm currently using intel core i7 8700 with a cooler master 120mm aio,whenever i play regular games the temparature spikes upto 84 degree,but in two games like gears 5 and nfs heat,whenever i play these two games the temperature hits around 95-100 degree celsius,is it a game issue or my aio cant cool my cpu in heavy intensive games,plz suggest me shall i change my liqued cooler from 120mm to 360mm or shall i clam warranty for a cpu replacement?
https://linustechtips.com/topic/1163571-cooling-issue/
Its a hot CPU.  I run a 65w CPU on a 120mm AIO and it does fine, can even mild OC on all core but quickly the AIO loses out.  I have mine in push/pull config to help its little radiator along.  I would recommend first checking your thermal paste, clean the radiator, and ensure no bubbles in the pump/block before replacing.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13361965
i did both changed the thermal paste and cleaned the pump as well but didnt worked out,case-cooler master mb500,2fans for intake in front and 2fans for exhaust in top and the 120mm in exhaust position!
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13362155
Can you add a second fan to the radiator creating a push/pull which will slightly decrease the temp of the water in the loop while in the heat exchanger (rad)?  This will help with temps a few degrees for sure.
You could also look to undervolt the CPU and see if its still stable, which will vastly increase temps.
If not I wouldn't hook anything less than a 240mm rad to that CPU personally.
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13362188
well to be honest couple of degrees wont be much bcz in both the games nfs heat and gears 5 it reaches 100 degrees,its a locked cpu and all the voltages in bios r in auto so any other suggestions?
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13362227
Mount as intake so its getting only the coolest ambient temperature to reduce the heat in the radiator, rather than recycled heated up air from inside the case (in its current position as rear exhaust) - easiest way to test this is just take it off as rear exhaust, leave side panel off and let it sit outside the case doing its job and see if that helps (using ambient temps) - if it does, a second fan will help also.  I also highly recommend TG Kryonaut as thermal paste, as it drops temps 3-5c in all applications I test.
The real fix is a better cooler for that hot CPU.  Its typically recommended (when running higher end components) to use 240mm rad per item (I.E. 1x240mm rad should handle any consumer CPU without an OC.  If you wanted to add a GPU to that loop it would be typically recommended to run a second 240mm rad.  I have ran a CPU and GPU on 2x80mm radiators before, but that was a 77w processor and a 130w GPU.
In my case, I have 2x240mm and 1x120mm rads on just my CPU (cause OC madness) - not even a 240mm rad could keep any decent OC on my chip (AIO) so had to build a custom loop.
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13362242
thnx will try and let u knowm,also if u have any better ideas plz let me know!
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13362258
Sounds like the pump is dying.
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
https://linustechtips.com/topic/1163571-cooling-issue/#findComment-13363657
