Hello I have recently been trying to make a decision on what to upgrade as my birthday is coming up within the next week. I am not sure if I would like to upgrade to a better monitor or to upgrade my cpu as it is bottlenecking my gpu, 144hz gaming is very tempting but one way or another I will need to upgrade my cpu eventually
Here are my specs:
GPU: RTX 2060
CPU: Intel Core i5 6402P
16 GB 3200 MHz ram
Samsung c24f390 60hz 4ms
Any Feedback would be appreciated!
https://linustechtips.com/topic/1162871-need-help-upgrading/
3 hours ago, immutablesky said:
It's a MSI B150M Bazooka Plus. Also do you think it would be a better investment to switch to an amd cpu/motherboard?
so a ryzen 5 3600 + a msi b450m pro-vdh max motherboard will cost $255
from a quick ebay search, a i7-7700 is $280
so yes, I think a switch to ryzen will be better
you already have good ram, you don't need to change that.
https://linustechtips.com/topic/1162871-need-help-upgrading/#findComment-13356548
Ok I will probably end up doing that, thank you for your input.
https://linustechtips.com/topic/1162871-need-help-upgrading/#findComment-13357229
