First build since 2012 (budget build)
nonsense42
i've been lurking in the forums for quite some time now, i decided to do a budget build since a friend of mine offered a the gpu listed for 90$ (not 100% sure if it's a good deal or not but i took it already)
all of my components have arrived except for the ssd
decided to put it together for now until the ssd arrives and i gotta say, i could've bought a better case. cable management in that case was a nightmare.
for whoever is deciding on a budget build, don't cheap out too much on the case.
also i kind of panic bought the cpu, was going to go for the 2600 but at the time of purchase they were going for 140$ and that same day i saw linus video on the fore coming shortages on components so i bought the 2600x instead at the listed price.
the next 3 days the 2600 went back down to 119.99. pretty sad about that. but oh well. live and learn.
so ran into a small problem while building this pc...
the case has a USB 3.0 connector and the MOBO has the header but apparently they don't match
the case connector has a blocked out hole and it won't fit the MOBO slot...
they both read usb 3.0 so... do i need to get an adapter or something?
