can you help me with my pc parts i have this: AMD Ryzen 5 2400g, memory G. Skill ripjaws V ddr4 3200Mhz kit 2x8gb, ASRock AB 350 Pro4, 450w corsair 80+, SSD WD Green (2.5", 240GB SATA III 6 Gb/s) and 1terabyt hard what i need to change and what graphic card to put in there?
https://linustechtips.com/topic/1162391-need-help/
dont need to, maybe you want to but then that means talking about what you want it to do but it currently can't do
Desktop benching:
https://linustechtips.com/topic/1162391-need-help/#findComment-13352379
Doubt you will get any help until you say what the problem is. What do you need help with? Taking a guess, your not happy with the graphics of the machine and want to upgrade. Yes you can put in a graphic card, and yes you may need to upgrade your PSU. But no one can help you with that until more information is given. What would you like to do with the machine that you can't do now? What sort of budget? That sort of thing.
https://linustechtips.com/topic/1162391-need-help/#findComment-13354807
Just now, xRuneLordx said:
I have all this parts, im gaming with my pc im looking for balanc with this procesor and graphic card. Maybe put rx 580 8gb but then do i need to change psu?
As a good preventive measure , it is recommended to get a good psu . A 550 watt or even a 500 watt would be decent . As for the graphics card , it depends upon your budget . Does your monitor supports either of G-Sync or Free-sync ? If so , it might be help it choosing your graphics card.
https://linustechtips.com/topic/1162391-need-help/#findComment-13356381
