Hello i have an old pc with the following parts :
cpu : i5-4690(yes without K)
gpu : sapphire r9 280 3gb
motherboard : gigabyte z97
8gb ram
650watt psu
I am looking for a good upgrade and i will upgrade the monitor to 1080p 144hz from 60hz.
But i am not sure which gpu should i get and i don’t want to waste my money for a gpu that my cpu can’t reach. Do you think a 1660 super will be ok? or is it overkill for this cpu and i should go to a RX 570 ? please help me
https://linustechtips.com/topic/1162387-gpu-upgrade-help/
1660 should be pretty evenly matched in many titles, although in others 4 cores could become an issue. What games?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352324
8gb ram
650watt psu
But i am not sure which gpu should i get and i don’t want to waste my money for a gpu that my cpu can’t reach. Do you thing a 1660 super will be ok? or is it overkill for this cpu and i should go to a RX 570 ? please help me
i want to play rainbow six, pubg a above 100fps and then games like jedi fallen order and new story upcoming games with 60fps at the heist graphics possible
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352336
If higher settings are your primary concern, then your current CPU should be fine
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352343
If you can afford the 1660 Super there's no point in going for an RX 570 instead. Even if you don't unlock the GPU's full potential now, you will eventually if/when you upgrade the rest of your parts later on down the line. And either way it'll be a massive improvement over your 280.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352355
i won’t upgrade the cpu ever i will leave it with the i5 , and yeah if i don’t have bottlenecks with the 1660 super i will get it.
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352380
If you want a cheap upgrade I’d op for a used 580 8gb or used 1660, will save you lots of money and give you the performance you want. Used rx588s go for 120 and u can get them usually for 80 ish
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352443
i don’t mind the money i just don’t want to spend the at something that my system can’t make a good use
https://linustechtips.com/topic/1162387-gpu-upgrade-help/#findComment-13352553
