question reguarding bluetooth hotspotting.
If I have my pc running on ethernet cable home internet and also hotspot my android via usb.. what exactly will happen. my goal here is to stay online if the home internet drops out. especially when gaming ect.
Will the pc prioritize which connection to use. will it use them both. or what. I don't realllly know what's going on here.
SORRY, I meant USB tethering in the title. but whatever works..
https://linustechtips.com/topic/1162314-question-reguarding-bluetooth-hotspotting/
10 minutes ago, Srijan Verma said:
could just mark topic as solved
it's not, I still don't know which connection my pc is using.. both. the faster one? the unthrottled one? What's going on here. will it use all my data even if the ethernet is plugged in. i duno cuz the hotspot is literally faster on my old laptop i havnt checked on my newer pc with a better network adapter.
These are both connections running at the same time. they are both taking data. they cannot be prioritized they are working together and the data is actually pretty high im using like 1mb every couple mins or so..
and my dataplan is 500mb a month. lmao wttth
that wont work
now here it is with mobile data ethernet data and wifi all at the same time. Im using usb. but could also be done with bluetooth to have all three connections. i didnt even know if your ethernet is on and wifi is on too they will both work independantly.
