Possible oversite need advice
Go to solution Solved by schwellmo92,
You should be fine with a single 8 pin as long as you're not doing extreme overclocking.
Ok so i should say to start with everything seems to be working fine for now. The concern is that the Asus prime x570-p has a 8-pin and a 4-pin 12v cpu power plug/port. my PSU is the cm650x which only comes with a single 8-pin. there are two modular 8-pin 12v ports on the PSU. However, i am using both of these to run power to my 2070 super. the concern/question is this something I should fix in the next week or can it wait for a few month? like i said at the start everything is running great and stable. no temp or voltage issues my 3800x is running solid at 4.2 GHz. I've left the 2070 super at out of box because, I know nothing about overclocking GPU's.
https://linustechtips.com/topic/1162238-possible-oversite-need-advice/
Even if they are doing extreme overclocking (or as close to that as you can get on the X570 Prime P), they should be more than fine with just the 8-pin.
