Hi, i'm currently upgrading my pc, running an fx 8150 and a gtx 1030 after my GPU died on me,
Currently i'm looking at an AMD ryzen 5 3600, a ASUS Prime B450M-A Micro, 16Gb corsair 3200, 1650 super 4Gb.
i have a 600w corsair PSU and a full sized case, with my storage already, although i may upgrade later.
i'm only looking for 1080p at 60 fps, but mostly just to upgrade very old hardware, any suggestions would be helpful
i have 500 GBP, 850 Cad, or 640 USD for budget
Thanks in advance
Edited by BadgerXL
forgot a screenshot
https://linustechtips.com/topic/1161623-advice-on-parts/
Yep, get a 1660 Super and definitely a different motherboard.
https://linustechtips.com/topic/1161623-advice-on-parts/#findComment-13345217
10 minutes ago, BadgerXL said:
will that matter if i don't overclock it?
it will matter if you upgrade to a more power hungry CPU in the future. Just get the better board, not worth saving 10 pounds for that.
https://linustechtips.com/topic/1161623-advice-on-parts/#findComment-13345289
