FD Node 304, EVGA GTX 2070S XC and Corsair RM650i
Sinros
Yesterday I bought all the parts, making sure to take all the clearances into consideration...
Seems like I did not take the cable into my calculations, The GPU interferes with the PSU cables by just 2cm.
A shorter card would fit while closing some of the PSU cable connections.
Fortunately I have a different build I can use the case for,
However could anyone please recommend a mini itx case that would 100% fit 2070S XC (27cm) and RM650i (160mm ATX) together?
Hello,
https://pcpartpicker.com/products/case/#t=9,10&sort=price&page=1
One of those should work, with this selected parts :
PCPartPicker Part List
Type Item Price
Video Card EVGA GeForce RTX 2070 SUPER 8 GB XC GAMING Video Card $523.98 @ Newegg
Power Supply Corsair RMi 650 W 80+ Gold Certified Fully Modular ATX Power Supply $160.57 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $704.55
  Mail-in rebates -$20.00
  Total $684.55
  Generated by PCPartPicker 2020-03-03 06:33 EST-0500
2 minutes ago, Plouffe said:
Hello,
Type Item Price
  Total $684.55
It shows the Node 304 as well, which doesn't seem to fit them.
I bought the Node 304 because the list showed it as compatible.
- From the Node 304 website (https://www.fractal-design.com/products/cases/node/node-304/black/) :
GPU max length
310 mm (when 2 HDD slots are removed; graphics cards longer than 170 mm will conflict with PSUs longer than 160 mm
- For the H210 (https://www.nzxt.com/products/h210-matte-white) :
GPU Clearance: Up to 325mm
GPU Max Thickness: 44mm
PSU Length: 311mm
The Phanteks Evolv ITX has a similar clearance, same for the FD Define Nano S.
GPU max length
PSU Length: 311mm
So the Nano S, H210 and Evolve are good to go?
