Difference between KFA2 1660 (Super) versions?
Go to solution Solved by KaitouX,
57 minutes ago, Xiee said:
The EX versions are probably factory overclocked a bit more than the others.
While this is correct, the biggest difference is the cooler itself, the cooler on the EX is better than the one on the basic version.
The images showing the heatsink on the links posted by @Ralf show it pretty well.
Heatsink on the basic model:
Heatsink on the Ex model:
And the fans also look different, which is pretty visible in close ups of the cooler.
I am currently looking for a GPU for a budget gaming system and I came across the KFA2 1660 and 1660 SUPER.
However I am somewhat confused by the fact that there is a "EX" version of each of those cards.
There is a 1660, a 1660 EX, a 1660 SUPER and a 1660 SUPER EX.
I was looking to buy the 1660 SUPER non-EX since I heard that the 1660 SUPER is very close in terms of performance to the 1660 TI but unfortunately it is out of stock at the reseller where I buy my parts.
Is there any substantial difference between the normal and EX versions or what's up with this product segmentation?
https://linustechtips.com/topic/1161211-difference-between-kfa2-1660-super-versions/
http://www.kfa2.com/kfa2/graphics-card/16super-series/kfa2-geforce-gtx-1660-super-1clickoc.html
http://www.kfa2.com/kfa2/graphics-card/16super-series/kfa2-geforce-gtx-1660super-ex-1clickoc.html
As you can see(or can't see) the EX version has better cooling and 30MHz higher clocks.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
