I undervolted R5 3600 by -.05v offset and I still get non-undervolted results in Cinebench 20, both single and multi core which is good. Yet hwinfo shows the highest clock 4.175ghz and mostly single core max is 4.150ghz. Is this the best way to undervolt? Why is it not hitting 4.2? Temps are never over 75.
https://linustechtips.com/topic/1161203-ryzen-5-3600-offset-undervolt/
not cold enough for this particular CPU, pull it near 0C and you'll see 4.2GHz. That's how boost on Ryzen works.
You could also try raise the power limits
Desktop benching:
Before I did the undervolt it would hit 4.2ghz just doing simple tasks and temps would be 5c higher. I did this undervolt a month ago and hwinfo is always on when PC is on. Never seen it 4.2ghz once. Max is always 4.175ghz
but the score has not changed right?
Desktop benching:
10 minutes ago, lafrente said:
Nope, single & multi can hit same scores. Hwinfo reports offset is working.
there you go. It's possible that 4.2GHz is only reached really briefly so the scores dont change
Desktop benching:
