Is a dual 120mm radiator as efficient as a 240mm radiator
Solved by W-L,
7 minutes ago, JimTheKid said:Are dual 120mm radiators as effective as a single 240mm radiator and would a 120mm and 240mm be fine together in a dual config
They will be within margin of error as long as the surface area being that the fin density between the two are similar. In general though it is better to have a single longer rad than shorter thicker rads, but as you still have 240mm total it will be essentially the same.
For a single CPU and GPU for a custom loop it would be recommended to have 360mm minimum of cooling if you are aiming for silent performance, more the better of course.
