best quiet airflow fans?
SeanAngelo
i'm planning on buying the Corsair 200R soon, and i'm wondering what are the best airflow fans out there?
I'm currently stuck with these noisy Casecom 120mm/140mm case fans, and i want a fan that offers good airflow but also stays quiet.
Thanks,
Sean
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Noctua, but I use corsair af120's with mine and it's still quiet.
Muh rig: i7 4770k, Cooler Master Hyper 212 Evo, MSI Z87 G45, Kingston Hyper X Blu 8GB, Samsung 840 EVO 120 + WD Blue 1 TB, Asus GTX 770 2GB, Corsair 200r + 2x Corsair AF 120 Blue + 1x Stock corsair fan, Corsair TX650, LG 27EA33V IPS, Steelseries Sensei Raw + QCK mini, CM Quickfire Ultimate Blue.
Gentle Typhoons.
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
what volts are the AF120's running on?
Old Rig
i run mine on motherboard header, but a guess would be 6-8volts.
using the LNA included with the fan is an alternative.
I am not sure, I just use the default motherboard header, but they never run full speed and temps stay below 60 degrees.
Noctua NF-S12A FLX is quite pricey but it's Noctua, it's for airflow and it's very quiet (although for me personally, they are quite ugly), be quiet! Silent Wings fans are great too, also take a look at Corsair AF120 or AF140 fans (I use these for my personal rig and they are pretty quiet, particularly the Quiet Edition)
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
i'm moving all my direct current AF/SP to the PWM versions. i have found they will
idle at a lower RPM through motherboard control without using the LNA harnesses.
i have to over-ride the mobo default (600rpm) on fan speed warring to 400rpm.
