Here is the link for my part list. Planning a basic portable pc for in home steam streaming from my main rig to the living room for social gaming. Also for Geforce now on the go hence the case with a handle for portability. Just wondering if I can make it more efficient for price to performance.
https://linustechtips.com/topic/1160778-stream-machine-build-plan/
PCPartPicker Part List
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor  ($149.99 @ Best Buy)
Motherboard: MSI B450I GAMING PLUS AC Mini ITX AM4 Motherboard  ($128.97 @ Amazon)
Memory: Patriot Viper 4 Blackout 8 GB (2 x 4 GB) DDR4-3000 Memory  ($40.99 @ Newegg)
Storage: Inland Premium 512 GB M.2-2280 NVME Solid State Drive  ($72.98 @ Amazon)
Case: Fractal Design Core 500 Mini ITX Desktop Case  ($59.50 @ Amazon)
Power Supply: BitFenix Whisper M 450 W 80+ Gold Certified Fully Modular ATX Power Supply  ($69.00 @ Amazon)
Total: $521.43
Generated by PCPartPicker 2020-03-01 11:33 EST-0500
this is going to be your secondary box, the capture box? Depending how complex your compositing is for your stream cpu usage increases for obs, but since it's a 4 core 8 thread it should be fine, as long as you aren't doing anything too crazy. I've only played around with obs and streaming a bit myself so...
I already have a stream capable rig I'm just building one to stream play from my main rig to a small portable rig so I can play games out in the living room without moving my pc. Also to carry with me to places so I can just use geforce now. The apu I want is more than enough and even can play some not too demanding titles on its own if I plan on gaming from it. Might need more ram for that last part tho.
Total: $521.43
Nice! basically the same thing but 100$ cheaper. Thanks man. The only thing I didn't mention is I went with one 8 gig stick for expansion reasons. Be able to throw in an extra stick and a discrete gpu for light on the go AAA gaming from the pc itself however thats not my main goal here but the option would be nice.
