3 minutes ago, ZilyanasDad said:
I have already tried uninstalling the display driver and rebooting in
If you're rubberbanding in games, it's probably not a graphics problem but a connection problem. if for whatever reason your PC is freaking out when you're using YouTube, reinstall your ethernet drivers.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1160760-new-build-problem/#findComment-13337606
26 minutes ago, ZilyanasDad said:
Whenever i load a youtube video it first loads with an error the load in properly. Anytime a YouTube video is playing i get lag in games even with a low ping. please help. 3700x rtx 2070 super
If your router has a QoS service for prioritizing data streams it could be set weird or behaving strangely causing connection issues. The problem isn't necessarily just your build. Could just be a poor wifi connection, do you know how to check for dropped packets?
https://linustechtips.com/topic/1160760-new-build-problem/#findComment-13337641
  • 2 weeks later...
