hi forum i have a windows 10 pc and want to run virtualbox macos everything is working fine until the instructions tell me to insert some command in the windows cmd but non of them are working these are the commands:
cd "C:Program FilesOracleVirtualBox"
VBoxManage.exe modifyvm "High Sierra" --cpuidset 00000001 000306a9 04100800 7fbae3ff bfebfbff
VBoxManage setextradata "High Sierra" "VBoxInternal/Devices/efi/0/Config/DmiSystemProduct" "MacBookPro11,3"
VBoxManage setextradata "High Sierra" "VBoxInternal/Devices/efi/0/Config/DmiSystemVersion" "1.0"
VBoxManage setextradata "High Sierra" "VBoxInternal/Devices/efi/0/Config/DmiBoardProduct" "Mac-2BD1B31983FE1663"
VBoxManage setextradata "High Sierra" "VBoxInternal/Devices/smc/0/Config/DeviceKey" "ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc"
VBoxManage setextradata "High Sierra" "VBoxInternal/Devices/smc/0/Config/GetKeyFromRealSMC" 1
i cant skip this step because macos wont be able to boot any ideas why this aint working
https://linustechtips.com/topic/1160700-virtualbox-issues/
yes i get that so to get it working i need to use these windows command prompt commands but when i start with the first one i get a message that indicates that the systam cant fiend the specified path
and that is my problem what is the issue and how do i solve it (it is pretty clear that some kind of file is not in the right spot for the command to work and i need to figure out wich one i have c and a d drive so its pretty messy)
https://linustechtips.com/topic/1160700-virtualbox-issues/#findComment-13337212
