Some more details might help. What games are you having this issue in? What are the specs of your computer? Is this the first time you've played games on this computer, or has it run these games fine before?
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
Heya,
I’m having this issue with all games but Fortnite. I’ve gamed on this computer for the last 6 months. It was perfectly fine before last week. My specs are:
Geforce RTX 2070
Intel Core i7-9700
16gb RAM
Hmm. Maybe your graphics card drivers are bad? Check and see if there are any updates for them. Also, have you been messing with any BIOS or overclocking settings recently? Those are the two things I can think of that could be causing it. Otherwise, I don't know why this would suddenly happen. Issues like this are often caused by using the wrong BIOS settings, but if you haven't changed them recently, and it was working fine before, then I don't think that's the issue. I'll let you know if I can think of anything else that could be causing it. For now, check for driver updates for your GPU, and let me know if you've been messing with any BIOS settings.
-- My PC Build --
Ryzen 7 2700x
XFX RX 590 Fatboy
Corsair CX650M
I just updated my drivers today. Didn’t work :( I haven’t messed with BIOS or other settings. I’ve used about half of my storage but I don’t think that would cause the issue? Super frustrating either way. Thanks for your help :)
What mouse?
What programs running?
·Ï¢årµ§·
i7 4790k · 32GB Kingston HyperX · MSI Gaming 5 · ... · 30" HP ZR30W + 27" Samsung 275T · 2x240GB Intel 530 in Raid 0 + 2x1TB Crucial MX500 · Lain-Li X2000F · Antec Signature SG-850 · BeQuiet! Dark Rock 3 Pro · Logitech Z5500 · Win10pro 64bit
...or lower, seems to be an issue with those mice.
·Ï¢årµ§·
