Hello
I have the i5 8600K Processor that Caps At 2666 Mhz Ram  i am Looking at upgarding Ram If i get 3200mhz Ram  Would it cause Any problems  I want to Get 3200Mhz Ram Becuase im gonna Put it in My New Pc That im Getting In a while that Supports 3200mhz
https://linustechtips.com/topic/1159993-ram-speed/
No it's not capped, it's only supported by Intel to 2666. In other words, you're on your own when you make it do anything higher, say 4000MHz. Anything below 4000MHz should be easy if you just apply XMP profile like most people do
Desktop benching:
https://linustechtips.com/topic/1159993-ram-speed/#findComment-13331782
