This only happens in one game (Blacksquad) It starts at 200+ fps then slowly keeps dropping (over 30 minutes approximately) until it stabilises at 30-50 fps. only rebooting PC solves that, the same game will keep the same framerate if reopened and other games are not affected (200+ fps), CPU and GPU usage stays very low and temperatures cool.
I already set windows power management profile to max performance and the power profile in nvidia control panel as well. and updated drivers
Could it be a memory issue? it's weird because other games work flawlessly
Any toughts about this? thanks
CPU: I7 8700k
GPU: RTX 2080
PSU: evga 750 G2
https://linustechtips.com/topic/1159985-frame-rate-drops-until-reboot/
check memory usage (you can do this through task manager) to see if it is a memory problem. It's possible.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Just now, azami88 said:
memory usage is below 50%
On VRAM as well? (you can see this in the GPU tab)
Laptop:
1 minute ago, azami88 said:
super low as well 0.6/8gb
So seems like it's not a memory thing.
Honestly, it might just be poor coding on the game developer's part. You could try to DDU and reinstall though.
Most graphics card issues can be solved by uninstalling and reinstalling your GPU drivers. If you haven’t done this yet (or haven’t used Display Driver Uninstaller to remove drivers), I’d recommend using Display Driver Uninstaller, found here: https://www.guru3d.com/files-details/display-driver-uninstaller-download.html (download links at bottom of page) and I’d recommend using the “Clean and Restart” option.
Once this is done, you can download new drivers by clicking on the links below and selecting your hardware.
Nvidia: http://www.nvidia.com/Download/index.aspx
AMD: https://www.amd.com/en/support
Laptop:
it would be surprising since it's no mainstream issue, (also all other games are fine so less likely to be gpu's fault) i will try to DDU and hope for some improvement
CPU: I7 8700k
GPU: RTX 2080
PSU: evga 750 G2
If it only happens in one game then the game is the issue.
Possibly but people have been fixing similar issues by modifying parameters on nvidia panel or windows options so i assumed there may be a chance to find a general fix
