Hello, so i own a computer that can run the games i want to play, but i'm looking for an upgrade that i can do on the pc, thats doesnt cost as much as a new pc, what should i upgrade first to get the most performance?
check my pc parts on the photos,
and what can i do now? overclock?
https://linustechtips.com/topic/1159503-help-with-build/
Probably your gpu. A 1660 is a pretty decent upgrade thats only ~$200 USD.
I build computers and networks. Fibre Optic is my only dream imaginable.
Studying for my CompTIA A+ and my CCNA, if you have any tips, let me know please!
Main PC: i5 8400, Saphire RX 570 4GB, ASUS TUF Z370 PLUS Gaming, 32GB 3200MHz Patriot Viper RAM, 256GB Kingston SSD, 2TB Seagate Barracuda HDD, 550W Evga PSU.
Home Server: 2x Xeon e5410, 64GB DDR2 ECC
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13327759
4 minutes ago, norlin said:
Also, is my pc a "good" gaming pc or is it trash? ;D
It's definitely not trash.
Easiest upgrade you could make is getting a new graphics card, though what you should go for will depend on what budget you have and what PSU are you using, so these two bits of information could be real useful for us to help you.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13327760
just FYI, a pcpartpicker.com list takes up a lot less space than CPU-Z screenshots, and we can get things like your PSU model and the like
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13327780
Thanks for fast and helpful answers! here is my computer from pcpartpicker, be in mind the psu isnt the same brand as mine but its similar to the corsair found on the site, mine has "80 PLUS, 550 Watt,"
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13327978
i have put an pcpartpicker! :)
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13328238
There are a lot of 80+, 550 watt PSUs that are crappy. Still, if it's all you can get, just slap an RX 570 in there and call it a day, or an RX 580 if you wanted to spend a bit more. Although we don't have a budget for what you want to spend.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13328244
Ok! Thanks! I have around 100-350 usd, be in mind I will buy used parts, so if there is any used parts for around 100-350, my psu is ”okay” from what i have heard!
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13328577
Considering the VS550 and your budget I'd probably suggest going for an RTX 2060 or something below that.
https://linustechtips.com/topic/1159503-help-with-build/#findComment-13329719
