Someone please help, so I bought 16gb 3600 MHz ram (2x8gb) and it’s all working however my memory sped is 2400 MHz my other 2 sticks are 2x4gb crucial at 2400 MHz is my new ram actually running on 2400 aswell or would it be 3600 when I check on task manager it says 2400mhz
https://linustechtips.com/topic/1159477-please-help-memory-speed/
RAM will run at the lowest common denominator for both speed and timings.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
If you want to run at the higher speed pull out the slow sticks and make sure XMP is turned on. Then hope it works.
