I have the same problem, no cpu bottleneck. My temps are fine and I did all the things people have wrote in the thread my gpu usage stays around 50-60% and maxes out sometimes at like mid 60s. I ran a benchmark with heaven and my gpu went to 100% so I was very confused. Can anyone help me thanks!
Specs:
GPU: gtx 1660 super Asus Tuf 6gb OC
CPU: i5-9400f (no overclock)
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15
MOBO: Asus Prime Z370-P II GA1151 (Intel 9th Gen)
https://linustechtips.com/topic/1159320-gpu-usage-low-help/
In what applications does your usage max out in the mid 60s?
Turn off VSync in games, if you haven't already.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326022
Which games? We don't know what games you play
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326028
4 minutes ago, Buster-Baker said:
Apex legends
This one is more gpu bound compare to others, what is your FPS and CPU usage in Apex?
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326035
8 minutes ago, Buster-Baker said:
cpu usage is at 70 percent and gpu is 65 with about 130fps on lowest settings
Apex is capped at 144hz, maybe that's why you don't get much higher FPS or GPU utilization. ?
If FPS stay the same when you increase the graphic settings then there is nothing wrong with your GPU imo.
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326058
Which resolution do you use? Sokething lower than 1080p?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326067
Try uncap Apex FPS and see if anything improve.
https://linustechtips.com/topic/1159320-gpu-usage-low-help/#findComment-13326074
