Could someone please help me build a rig for around 1500 CDN less is always better. I will be using this for gaming mostly and I live in Canada. I have all the peripherals. Some stuff I would like is Rgb :) and high frames on all low settings except for view distance in fortnite the frames I would prefer is a solid 240 with little to no stutter. I could go up to 1600 if needed. Thanks in adavance.
https://linustechtips.com/topic/1158927-build-help/
What monitor do you have?
https://linustechtips.com/topic/1158927-build-help/#findComment-13322477
1st question is WHAT GAMES?
2nd, where do you live? Big city would have a store like Memory Express.
RGB is really bad!
Fortnite, ok
Well what do you already have? A psu?
Ryzen 3600, Tomahawk MAX mobo, 2x8gb of Viper ram, $20 case, storage is whatever.
Peripherals as in monitor?
$1600cdn peso's. Yeah just do that.
https://linustechtips.com/topic/1158927-build-help/#findComment-13322566
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($229.99 @ Newegg Canada)
Motherboard: Asus Prime X470-Pro ATX AM4 Motherboard  ($139.99 @ Canada Computers)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($100.99 @ Newegg Canada)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Mike's Computer Shop)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Canada Computers)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($509.99 @ Mike's Computer Shop)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($69.99 @ Canada Computers)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($78.50 @ Vuugo)
Total: $1289.43
Generated by PCPartPicker 2020-02-24 21:14 EST-0500
https://linustechtips.com/topic/1158927-build-help/#findComment-13322764
Hello there,
I already suggested you a nice build in one of your other threads (3600, 2070 Super, 16GB Ram, 500 m.2 + 2tb HDD) - do you want to upgrade your monitor to make good use of all those frames your new machine is going to deliver? We could include one in your build and stay within budget!
https://linustechtips.com/topic/1158927-build-help/#findComment-13323026
8 hours ago, ShinRamen said:
Hello there,
That would be awesome!
https://linustechtips.com/topic/1158927-build-help/#findComment-13323657
