PCPartPicker Part List: https://pcpartpicker.com/list/MsX6Nq
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($308.89 @ Amazon)
Motherboard: Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard  ($122.99 @ Amazon)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory  ($99.99 @ Newegg)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($87.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ Newegg)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card  ($499.99 @ Amazon)
Case: NZXT H510 ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($78.36 @ Amazon)
Total: $1322.17
Generated by PCPartPicker 2020-02-24 06:36 EST-0500
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13320838
Any tweaks? go ahead and tinker
I would go for a different board - better suited for a Ryzen 7 - and a better PSU, but otherwise looks good.
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.89 @ Amazon)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $1325.70
Generated by PCPartPicker 2020-02-24 06:43 EST-0500
But it does depend on what you do on this PC. For example if this is more of a gaming tower, it could be worth it to spend less on the CPU and more on the videocard, like this:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB XC ULTRA GAMING Video Card  ($693.98 @ Newegg)
Total: $1381.80
Generated by PCPartPicker 2020-02-24 06:44 EST-0500
You could also think about getting a separate cooler with this system. The stock cooler on Ryzen is fine, but not that quiet. Two more case fans would work good too, something cheap and simple like two Arctic F12 fans for example.
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13320847
Total: $1325.70
  Reveal hidden contents
Total: $1381.80
I dont understand ? why  is my psu bad?  ty tho :)
Edit: I have one more question, would it be a good idea to do a midweek madness sale and get a psu from there.
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13321889
Just now, boggy77 said:
What do you mean by same type of psu? The psu you picked isn't bad, there are just better ones for the same price. There is a psu tier list in my signature if you want to take a look.
I mean bboth 80 plus gold 550 w. Also im planning on adding a rgb strip any ones you recommend. Perferably not super expensive. I switched the mbo to the one you reccomended and put the fans so ty
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13321899
The MWE Gold your chose certainly is not bad, but the RMX is more the sort of PSU I would recommend with a system like this one.
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13321998
could you ossibly answer the second question
SHould i buy an EVGA during midweek madness
Also i asked the other guy and im sorry if im bthering you but do you recommend any good in pc rgb strips preferably cheap.
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13322048
EVGA PSU?
An EVGA PS, G2, P2, or T2 would have a similar quality to the RMX. If you can get those for a  good price, it could be worth it.
https://linustechtips.com/topic/1158705-pc-part-picker-help/#findComment-13322053
