I'm helping my mom with getting a new pc since her pc is getting quite slow (+ some problems with crashing)
The budget for the build is a place between 500-1000 Euro.
The aim of the build is for it to be a small form factor for work (basically only Microsoft office),
The only things that is needed is the case, parts and the OS (Windows) (not any peripherals)
The pc should not end up being to loud
Thanks for any help :))
https://linustechtips.com/topic/1158551-help-planning-a-small-form-factor-pc-build/
PC: Ryzen 9 5900x | RTX 3080Ti | Asus Prime B450-PLUS | ASUS ROG Strix 1000W Gold | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD + 2TB NVME + 6TB WD BLACK | Windows 10 Pro + Windows 7 Ultimate
Laptop: MacBook Pro 15" 2018 | i9-8950HK | Radeon Pro 560X | 32gb RAM | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 16.5 with Dopamine 2 + Trollstore 2
Ireland is darn expensive, and quite restricted in parts available. You're sure to be part of the EU?!
This should serve well, but a good fm2-system with 65W/45W apu and 16gb ddr3 dual-channel would do as well at up to similar speeds - and at several €€ less; fm2 apu and mainboard used should be sub €50, add €30-50 for 16gb ddr3 (1600/12800 at least) dual channel and you've saved more than €100.
CPU: AMD Athlon 3000G 3.5 GHz Dual-Core Processor  (€65.64 @ Custompc)
Motherboard: Gigabyte B450M S2H Micro ATX AM4 Motherboard  (€75.74 @ Custompc)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3000 Memory  (€86.86 @ Custompc)
Storage: SanDisk SSD PLUS 480 GB 2.5" Solid State Drive  (€84.08 @ Custompc)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  (€47.90 @ Komplett)
Power Supply: be quiet! Pure Power 11 CM 400 W 80+ Gold Certified Semi-modular ATX Power Supply  (€97.01 @ Custompc)
Total: €457.23
Generated by PCPartPicker 2020-02-23 23:20 GMT+0000
this would help a lot more if you told us which country you're from or where you can get the parts from.
I'm actually from Norway (so the budget is about 5000-10000 NOK), the site I'm most likely gonna use is komplett.no
PCPartPicker Part List
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor  (kr1169.00 @ CDON NO)
Motherboard: MSI B450I GAMING PLUS AC Mini ITX AM4 Motherboard  (kr1486.00 @ CDON NO)
Memory: Corsair Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory  (kr628.00 @ CDON NO)
Storage: Crucial BX500 480 GB 2.5" Solid State Drive  (kr843.00 @ CDON NO)
Case: Fractal Design Node 304 Mini ITX Tower Case  (kr899.00 @ CDON NO)
Power Supply: Fractal Design Integra M 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (kr899.00 @ CDON NO)
Total: kr5924.00
Generated by PCPartPicker 2020-02-24 08:27 CET+0100
you can get windows off ebay for a few dollars.
Total: kr5924.00
Do you think these parts will work
PCPartPicker Part List: https://pcpartpicker.com/list/4VNxTC
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor  (kr1579.00)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard  (kr759.00)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  (kr899.00)
Storage: Crucial BX500 480 GB 2.5" Solid State Drive  (kr729.00)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  (kr899.00)
Power Supply: Cooler Master MasterWatt Lite Full Range 500 W 80+ Certified ATX Power Supply  (kr515.00)
Total: $0.00
Generated by PCPartPicker 2020-03-01 13:48 EST-0500
