[SOLVED] Vertical gpu mount or vertical bracket
Hey guys,
 So... putting gpu horizontally is better than putting it vertically, we all know that. But I want to try placing my gpu vertically so I was wondering if it's better buying vertical bracket and putting it in there or putting gpu in vertical gpu mount that is in my pc case already.
Please help.
If you want to use Vertical, then get the Cable Mod Vertical kit. Don't use your case mount unless its water cooled.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
