GPU Locked At 1817Mhz With Adobe AE Running
AAura
I'm not sure if this is normal but when i try and do a preview/render on Adobe AE, with a very minial load, why do i get such an insane GPU frequency? The utilisation is low and the profile i'm using is the default one from a fresh DDU and Driver install/uninstall. Is this safe and just some weird bug?
It's probably normal while the software may quarry the GPU.
You could use GPU-Z and look at the sensors tab. Near the bottom, there's a listing for "PerfCap Reason" This will tell you the GPU state.
vRel = Reliability. Indicating performance is limited by voltage reliability.
VOp = Operating. Indicating performance is limited by max operating voltage(Hardware Limit).
Pwr = Power. Indicating performance is limited by total power limit.
Thrm = Thermal. Indicating performance is limited by temperature limit.
Util = Utilization. Indicating performance is limited by GPU utilization.
Idle = Idle low power states.
Hope this helps, if not right now, perhaps in the future.
Don’t see the frequency being insane. Doesn’t really mean much compared to load.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
How is that insane? The jump in clocks is just to prepare for a coming workload, usually if it lasts for a bit of time it will come down
Desktop benching:
I don't understand how the clocks work, all i see is 1817Mhz on an unstable Vega 64 LC which normally clocks between 1655Mhz - 1782Mhz under 100% load.
I'll try this later because the download links on Techpowerup are dead rn
it can boost higher when cold and current draw is low
Desktop benching:
My GTX1070 sits at my OC clocks (2025Mhz Core and Ram is clocked up too) when rendering/encoding, while my GPU usage is variable but low at 5-30% maybe....
Preparation and all that... it wants to do the work as fast as possible, clocks high, even with limited usage, its still as fast as it can be.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
