2 days before, i got a Z170 motherboard <ASUS ROG MAXIMUS VIII RANGER>
And now my GPU GTX 1070 is running at PCI-E 3.0 X8 speed on this board. I dont know why.1842240852_QQ20200222053542.png.dc2b237107f494237fb34f8bac753736.png
I tried to run Render Test, but it still running at PCI-E 3.0 X8. And i have checked bios settings, only can change pcie gen1/2/3.
This matherboard only have one M.2 slot, and i put a WD SN500 NVME drive in it. idk if it will change the PCI-E Slot Speed to X8.
Hope somebody can help me. Sorry for my poor english,
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/
Take the card out, put it back in. PCIe x16 is a long slot so sometimes it just doesnt entrely go in.
Desktop benching:
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13314797
check the box of the mobo, it usually says if an M.2 shares the PCI-E resource or no
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13314815
To be honest, you shouldn't sweat it if you can't get it running at x16. A 1070 won't really take a performance hit from half bandwidth.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13314818
I tried to take card out and put in. And when i going to the system, GPU-Z still show PCI-E 3.0 X8. Can this problem caused by PCIE SLOT broken?
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13314916
You said is right. When I play games, FPS is Good. I just wanna know what the reason is and try some ways to solve it. :) Thank you
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13314920
Remove everything from the other PCIe slots and turn off the iGPU and start from there.
If you've plugged ANYTHING into another PCIe slot that shares the GPU PCIe slot it will drop to 8x. If you have nothing in the other PCIe slots, then it might be the NVme slots.
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13315187
The two grey PCIe x16 slots share bandwidth (both go to x8) if both are in use.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13315215
1 hour ago, Sla1neVact said:
I only put a gtx 1070 and a M.2 Nvme ssd.
Try the other grey slot, what does it say in GPU-Z?
https://linustechtips.com/topic/1157885-pci-e-30-x8-problem/#findComment-13316518
