Timings is not latency, combination of frequency and timings gives you latency. Here they have equivalent latency with greater transfer rate. Whether it matters depends on the CPU, board and budget.
Desktop benching:
Oh, my bad.
13 minutes ago, boggy77 said:
they are very very similar. the 3600 will probably be like 1% better in some games
Ok, well it doesn't matter because I managed to get a deal on the 3600. It ended up being cheaper to get that, surprisingly.
There are a lot more timings that effect RAM latency, even more than the usual 3 to 5 that are advertised. It’s easy to overthink them. Anyway, the timings are how many clock cycles it takes the RAM to perform a given task. Conversely, the mhz is twice the number of clock cycles it is performing in a given period of time (hence the “double” in “Double Data Rate”).
If you ever want to calculate the latency from these numbers for yourself:
Random timing #1, 3600Mhz/2 = 1800Mhz/1,800,000,000 clock cycles per second.
1000/1800Mhz = .555555555 nanoseconds per clock cycle. .555555555 x 18 clock cycles = 10 nanoseconds of latency.
Random timing #2,
3200/2 = 1600Mhz
1000/1600Mhz = .625ns
.625ns x 16 = 10ns of latency.
In this case, latency is the same. Go with the higher speed RAM for the overall data rate benefit. If the timings were say... 20 for the 3600Mhz sticks, and only 15 for the 3200 Mhz sticks, then it might be worth it to go with the lower clocked sticks to get the overall lower latency. Usually never works out this way though, and generally higher clocked stocks will end up with the same, or lower, ram timings.
