1 hour ago, Fajrian said:
i have been installed freeNAS to my server, but i have any problem in my freeNAS OS, cause in my freeNAS the plugins was errored and rise notification like this picture below, anyone help me to solved my problem?? Please!!
You do not have permission to write to the lock file (by design), so something is already doing it, or whatever was doing it has failed and left the lock file. So the correct thing to do is if you're not doing anything, delete the lock file and try again.
which key file should I delete? can you give a hint? or can you guide me to reset my favorite screen? help me please!!
  • 3 weeks later...
3 hours ago, Fajrian said:
i can't find that, could you help me to solve my problem??
If /mnt/server_1/iocage/.plugin_index/.git/config.lock file doesnt exist, then check permission on /mnt/server_1/iocage/.plugin_index/.git/ directory.
Run an ls -l /mnt/server_1/iocage/.plugin_index/.git/ and check who the owner is and the read/write permission. It should probably be owned by root and have permission 775 applied.
e.g chmod 755 -R /mnt/server_1/iocage/.plugin_index/.git/
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
