Gigabyte has a couple 1080ti cards available some with AIO some air cooled some even with a water block.
my question is if I got This could I run sli with This?
are they actually the same card just with two different cooling solutions?
sorry if this is a topic that’s been created already I had a hard time finding an answer.
https://linustechtips.com/topic/1156201-same-card-different-cooler/
Please do not buy that card. That price is absolutely bullshit. Not to mention you will see no improvement for the most part..
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
1 hour ago, WyRay said:
I’m not buying either of those cards I was just using the Newegg links as a reference.
If think that they would work together. Everything is exactly the  same about the card, just the cooler.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
Hell no. I’ve seen new 2080ti cards for that price.
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
How cheap is cheap
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
I personally wouldn't buy it but to each their own
14700k
2tb seagate hdd
Pny 5070ti
Ps5 Pro
Series X
3 hours ago, caldrin said:
As far as I know it should work fine.. but is SLI even worth it ? I dont think many games work with it very well..
Probably not worth it. But might be able to swap out the shroud/cooler and turn it for a quick buck.
I haven’t purchased it yet though so I was just entertaining the idea of trying it out.
