Ryzen 7 3700x and Asus strix x570-F around 600 dollars
Ryzen 5 3600 and msi b450 tomahawk max around 300 dollars.
Ryzen 9 3900x and Asus strix x570-F around 750 dollars
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1155376-700-budget-help/#findComment-13295113
4 minutes ago, Meiyer said:
Preferably Z390 chipset with an i7 cpu
why?
https://linustechtips.com/topic/1155376-700-budget-help/#findComment-13295114
What are your current specs, and what is your use case, does it include applications that could specifically benefit from Intel CPUs?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1155376-700-budget-help/#findComment-13295116
