Compression for Website
Solved by WereCatf,
25 minutes ago, Nolanrulesroblox said:how do i compress like youtube?
I don't use any Adobe-products, so I can't give any specific details, but when you're exporting a video, you need to select a video-codec that can compress well and you also need to set a lowish bitrate for it. For example, exporting with VP9 or H.265/HEVC video-codecs and at, say, 6-8Mbps bitrate you can get rather small files.
