Hello there, I have a question regarding case fans certain compatibility with various adapters.
You see, I have four 3-pin case fans connected to the motherboards 4-pin ones. They all work without any problems and I hope it stays like that.
But unlucky me one fan turned out to be particularly louder than others. Looking at the BIOS, it turns out it is working full speed.
I realized I had put it on the place where the Water pump was supposed to go. Looking later at the motherboard, I realized I couldn't put it anywhere else.
After researching solution for my problem I found various adapters for case fans, but mostly 4-pin ones who would connect two fans into one.
So my question is this: Can you use 4-pin adapters / splitters to connect (two) 3-pin fans into one?
Also I saw variations which use MOLEX cable, but I'll use it as a last resort...
https://linustechtips.com/topic/1153878-case-fan-splittersadapters/
Yes you can, not more than 3 i think though
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Water pump headers are usually set to operate at 100%. Since the flow rate doesn't need to be variable, it's just go at full voltage & use fan control for temps.
I use one of these (https://www.amazon.com/gp/product/B00IF6R4C8/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1) for any system that doesn't have enough headers for each fan. It gets power from a SATA connection, so you can max out the adapter without worrying about over-drawing the header.
And as long as there's a fan on header #1 on it, you'll get the RPM readings from it.
