Hello, I have been having problems with my games. I was simply playing some Minecraft, noting too stressful, and when i press F3 it says that I am getting 83 FPS but it doesn't feel like that at all. Instead it feels more like 20 fps. The game is hard to play even though I have a GTX 680, and an Intel Xeon 3.3GHz. I even have a high refresh rate monitor. Does anyone know how I might fix this?
https://linustechtips.com/topic/115375-frame-rate-problems/
Try setting the refresh rate of your monitor lower (to 60Hz, maybe) and see what happens.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/115375-frame-rate-problems/#findComment-1542359
I can tell you that I've heard that minecraft will have weird issues with displaying the exact frame rate, my idea is to try a reinstall of minecraft, and that could fix that. Just be sure to back up a copy of your world saves if you have any cool ones you want to keep.
https://linustechtips.com/topic/115375-frame-rate-problems/#findComment-1542871
That wont help, minecraft doesn't really install anything. It just copies the .minecraft folder and files to the directory. You can move the minecraft folder anywhere on your computer and launch it with no problem (directly from the jar.) The only difference reinstalling would help is if you have a bunch of mods, that would eliminate if it is a mod.
You could try making a different world and see if it still happens, if it doesn't then it probably is a corrupt chunk.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/115375-frame-rate-problems/#findComment-1542906
