Ram. 16GB should help a bit. Though what games are you struggling with. What drive do you have?
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13282302
Needs more RAM. Mor Pow-wah!
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13282304
Just now, Turtwigz said:
I drop rates on Apex legends. I also have 2 monitors in total maybe that might be why?
What kind of drops are you experiencing? Ram will definitely help for sure. Are you running a single stick? If you are that would explain a lot. You are running in single channel, having memory bandwidth.
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13282310
Yup just single stick lol. I go to 130-140 fps to 90-100fps randomly
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13282313
Swap in another 8GB stick. Make sure the ram is installed in the correct slots, otherwise if they are in different channels it will still be single channel.  Also, dips are normal in games. Nothing you really cannot do about that.
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13282323
What ram sticks would you recommend? If i went for 32gb
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13284576
Are you gonna do anything else on the pc apart from playing games? If not than you don’t need 32gb, better to buy higher quality 16gb instead (higher mhz, less cas)
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13284600
Honestly as stated above, 32GB is not really needed. If anything, get some ram of around 3200-3600MHz 16GB kit.
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13285616
43 minutes ago, Turtwigz said:
I also oc to 4.5-4.6 ghz, should i buy a better cooler? or it doesnt really matter
Check the temps, if they are acceptable than don’t bother.
                                          WHIRO
https://linustechtips.com/topic/1153704-need-help-upgrading/#findComment-13296888
