i live on an acreage in Alberta and the best WiFi package i can get is up to 10mps but it usually sits at 3mbps or even lower than 1, only at night it goes up to 10mbps. Trying to game online is almost impossible my ping is always around 200 is there any way to get better internet? would a better router do anything?
can barely use my gaming pc!!
https://linustechtips.com/topic/1153696-acreage-internet-help-fix/
Welcome to internet in the sticks. And the answer is probably no. You say "the best WIFI..." so it sounds like you are getting local wireless beamed to you... or maybe cellular? But still, probably not. It's so slow because it is the only thing around and everybody around you is on it. That is why the speeds go up at night. You have 2 options. Move or live with it.
