Ubuntu is free and fairly user friendly. You'll have to learn a little bit compared to windows.
There's plenty of guides on how to create a minecraft server on Linux. Really depends on what kind of server you want set up though,
Quote
I build a minecraft server, i used ubuntu. And I recommend you to use Ubuntu or Debian, because they are free and friendly, support GUI and CLI both.
I will give you a tutorial, when you setup your minecraft server, you can run these scripts.
URL: https://web.orwtmc.top/Minecraft-On-RaspberryPi
OS you can use Ubuntu 18.04 LTS Desktop or Server.
If you want to use a java server, you can just view https://web.orwtmc.top/Minecraft-On-RaspberryPi
If you want to use a bedrock server, you can go to minecraft.net and there was a tutorial, hope i can help you.
