I saw this invertible case from be quiet, I think it was the silent base 801.
Complicated inversion process
Why not just turn your case upside down to invert it? Someone could make a case with modular feet that you can move to the top to keep the case from getting scratches and such.
Normal:
Inverted:
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
https://linustechtips.com/topic/1153256-simple-invertible-case/
Nothing stopping you from inverting basically any case in that fashion (Corsair Air 540 and 240 's are common for this). But adding the tooling to offer a feature 99% of users will not use is a waste of money in the eyes of most manufacturers. Yes,even just an option to put feet on the top.
This would also require basically All I/O to be "Front" or "side" oriented. There's a LOT of current cases with top I/O now that would make USB ports impossible to use, and Power/Reset buttons inconvenient to use
https://linustechtips.com/topic/1153256-simple-invertible-case/#findComment-13279040
