Gpu fan not spinning
Solved by LIGISTX,
3 minutes ago, MADEAR said:When i turn on my pc it get stock in startup screen and my gpu fan stops spinning after 5 sec, but they only stop when my cpu power cable is on, so does anyone know how to fix?
What GPU is it? Many newer GPU's have a no fan mode... The fan doesn't turn on until its under game load.
What do you mean when the CPU power cable is in? Without CPU power, the motherboard will not even post. Are you having an issue getting the PC to boot or POST?
