*im wondering about wow big/many radiators do i need if im going to watercool an gtx Titan and a intel 3770k?
 Or do i need one more radiator to cool the liwuid down?
the radiator im talking bout -> XSPC RX240 Dual 120mm Fan High Performance Water Cooling Radiator
*bonus question:  do i fit 2x 12omm raiator in the front of a cm trooper? or do i have to remover the harddisc cage?
https://linustechtips.com/topic/11524-water-cooling-radiator/
it depends how much overclocking do you want, how load do you want the fans to be, are you using good static pressure fans.
you can fit the 2*120 rad in the top of the trooper {might have clearance issues from the vrm cooler}
if you want that rad in the front of the trooper then yes you need to remove both drive sled's.
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-122775
You can fit a 280mm radiator in the top of the storm trooper use one of those as appose to the 240 you want at the top.
If you want the build to be quiet you will have to install a 240 mm rad at the bottom of your case. You will only need to remove the bottom hdd cage afaik.
EDIT: Got Ninja'd
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-122780
EDIT: Got Ninja'd
thanks, this sounds like the best option for me i think. do you know if the rad will be lying on the side so that i can fit my pump and res beside it? where wud you put the rez and pump?
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-122972
Either get a bay res and pump combo or mount it to the side of the case next to the motherboard. The pump can go at the bottom of the 5.25" bay area.
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-122989
im thinking to have an 3770k prosessor overclocked to 4,5 ghz and a gtx titan witch overclocks itself
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-123082
Just remember the pump must go above the waterline of the reservoir btw.
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-123100
the higher is better? is it like that?
The reservoir always has to be above the pump. If at any point there is no liquid in the pump while it is on it will break. Therefore the reservoir must always be above the pump so the gravity pushes the water into the pump inlet.
https://linustechtips.com/topic/11524-water-cooling-radiator/#findComment-123249
