Operating System
Go to solution Solved by LukeLinusFanFic,
Don't install Windows XP. It's super virusy. May I recommend chrome os or Linux mint?
You probably need to load special disk controller drivers for the disks to be seen during Setup. If you go to the support and driver downloads website for your specific laptop there should be a driver there for something like SATA that is called an "F6 driver" or a setup driver. This is the driver that you need to load during Windows XP setup. You must put it on an optical disc and insert the disk after pressing F6 at the prompt when Setup loads.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/1152399-operating-system/#findComment-13272119
7 hours ago, AcerDark said:
i know but i need a light windows that can run on my laptop.
i have windows 7 but its super laggy
That's what the os' I mentioned are for. They are designed to be super light, far lighter than windows
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
https://linustechtips.com/topic/1152399-operating-system/#findComment-13273077
