I have a Xbox 360 wired controller to play FIFA 20 on PC, but it isn't working well and I would like to get a new one.
I'm searching some models, like the wireless Logitech F710, but is kind of expensive.
Does any of you knows a cheap and wireless controller to PC?
Ps: *Xbox's controllers aren't an option, they use non rechargeable batteries.
*Just say the controllers you know that's compatible with FIFA PC, dont wanna use programs like Xpadder
peace
love u @linus
https://linustechtips.com/topic/1152306-controller-for-fifa-pc/
If Xbox controllers aren't an option only because they don't come with rechargeable batteries, why not just buy a 4 pack of rechargeable AA batteries and charger?
Its an extra $25 CDN and you can quickly swap the batteries instead of waiting for the controller to charge again.
https://linustechtips.com/topic/1152306-controller-for-fifa-pc/#findComment-13272914
