USB 2.0 wifi dongle, No Internet Secured connection to my router
Tristerin
I bought 1 of these expedited out of Florida for a project I wanted to complete and then a bunch of them from China @ $1 each.  The expedited one arrived but doesn't work.  Heres what I have tried:
https://www.ebay.com/itm/123697558322?ul_noapp=true
Disable all security on Router (TP Link Archer C5 AC1200)
Change Wifi log in PW
Change Wifi log in PW to match Network Security Key
Let windows DL driver on install
Tried 2 different Realtek Drivers for unit
Reset Router to factory settings
All other devices in my home I can connect or disconnect at my leisure (laptops, Cell phones) with no issue.  I believe its just the uber cheap dongle doesn't work.  The issue is it will see the network no problem but when I go to connect it will not connect demanding security network key.  90% of the time it will not accept that key, but on the 10% times it does it gets "No Internet, Secured" (and I can see it on the admin panel of my router).
I actually was troubleshooting it and it connected to the internet once...was only getting 10mb up and 1mb down and after a restart could not get it connected again.
Anyhow Im not sure if its just a POS hardware cheapo-depot that I bought that's just non functional (cant get it to work with Manjaro, or Windows 10 on any of my machines) or it requires some subtle thing to get it done.  I don't see that being an option but thought Id ask here.
Have already got another adapter on the way that's also AC1200 so I can get better streaming on that PC should I need it but if I can salvage this dongle that would be cool too.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
