Hi there first of all, im still new to this throttlestop and i've watch guides from youtube and seems like it does not help it all...
I just play 30 mins of Division 2 with all medium graphics. ends up, my laptop runs around 80 - 90 ish of degree...
Below are my settings for throttlestop. Kindly help me with this guys :( not only division 2 gets hot but other games as well. Such as Apex around 75 - 85. or csgo.
Im not sure where did i go wrong or did i missing something? All i did to the throttlestop was the Cpu core & Cpu Cache. and i dont think i can go beyond 63.5mV
few reason is because sometimes, when playing in the mid game, it will suddenly freeze and it wont auto restart, so i have to manually restart it myself.
image.png.211225690d89ddec13f26d0680d6926f.pngimage.png.529a07fbecd21e633c5b67c29a40ff6e.pngimage.png.6f4c2cb4a7a721823d6878055a2e0333.png
I hope these info could make you better tho... still new to these stuff so yea..
Kindly help me guys, i cant ply games with above 80 degree :s
https://linustechtips.com/topic/1151781-throttlestop-need-help/
For my laptop anyway you need to apply the same offset for CPU core and CPU cache in order to actually apply the right settings.
Desktop benching:
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267018
4 minutes ago, Normen said:
Its still new tho, not even a month.. so yea, how do i do this :s
Not much dust in a month...are you using it on the desk, maybe get a cooling pad.
As a software solution try fps limiter.
Throttlestop can in fact make your system throttle all the time if you underclock too much...
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267053
Yea, i did but seems like it does not do much as in the fan is not doing anything lol. Its not even cool. Any recommend for cooling pad?
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267057
oh, well i mean i did not go beyond than 63.5mV and im not always modify it
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267062
2 minutes ago, RageTester said:
If you want max performance, you must reduce detail quality or resolution... or get an external cooler like this: https://www.fasttech.com/products/1506/10022131/9652150
that could work but does it fit to all kind of laptop?
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267092
It's advertised to have different size fittings, but only buy something like that if you can't reduce the heat levels produced...
https://blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/12/
https://linustechtips.com/topic/1151781-throttlestop-need-help/#findComment-13267141
