23 minutes ago, AlexWarFire said:
I hear my power supply shutting down
What exactly are you hearing? What noise does a shutting-down PSU make?
I doubt it's the PSU, since if the power supply shuts down, the computer does too.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1151616-freezing-problems/#findComment-13265837
When my computer usually shuts down, my PSU makes a clicking noise, it’s an EVGA btw so this noise is normal, and then it freezes.
https://linustechtips.com/topic/1151616-freezing-problems/#findComment-13266139
Oh, also, I hear my fans ramping up just after the freeze just like if the computer had just started.
https://linustechtips.com/topic/1151616-freezing-problems/#findComment-13266141
