I don't think that should be a problem. Do the hoses fit at the top of the front panel? It shouldn't make much difference, but that's the usual way to do front AIOs.
Your GPU might run around 1-2 degrees warmer but for a beefy card like the Strix it shouldn't make a difference.
8 minutes ago, charbel1011 said:
somebody mentioned im getting hot air to my gpu i dont wanna break anything
you either mount the GPU as intake and hot air goes to the GPU, or as exhaust and hot air goes to the CPU. Either way something heats up more.
Primary PC:
PSU tier list
How many watts do I need?
3 minutes ago, charbel1011 said:
So i shouldnt change anything?
not if your GPU temps are in control
Primary PC:
PSU tier list
Actually people who put their hoses up instead of down. Are risking their aio to make bubbles and get stuck and burn out.
Nope its fine, push/pull was kind of a waste of money but its fine.
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
