I have a problem with my PC. I built it in February 2013. Here are the main specs:
i5 3570k
AsRock z77 extreme4
Patriot 2x4GB 1600MHz DDR3 9-9-9-24 1.5V
HIS 7950 IceQ Boost
Asus Xonar DX
Seasonic G-650W
2TB Seagate Barracuda
Basically I just got the BSOD code 0x000003b yesterday and I don't really know what the problem was. That was like the 5th BSOD with the same code for the last 3 months. It occured randomly. I have googled it and I found several alternatives to this problem.
1. Increase Vcore (DONE when first occured. That time my CPU was clocked at 4.2 GHz)
2. RAM problem, do memory test (DONE, I did memtest on both sticks, no problem found)
3. Check for hardware compatibility, update drivers (DONE, everything is up to date including the BIOS)
Last month I decided to reset my CPU into stock frequency, and reset everything in the BIOS setup except for the RAM config. For some reason yesterday it happened again, BSOD 0x000003b. This time I have no idea what could be causing this since my CPU is running at stock speed, voltage set to auto just like when first time I built my PC.
What is wrong with my PC? Is it hardware failure or perhaps OS failure?
"Yippie-ki-yay motherf**ker!"  ~John McClane
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/
Microsoft Support
Edit: Added quote from page.. not all, but a bit.
20x20_grey_minus.pngSYMPTOMS
A computer that is running Windows 7 or Windows Server 2008 R2 may crash when you use some IEEE 1394 devices. Additionally, you may receive a Stop error message that resembles the following:
STOP 0x0000003B (Parameter1, Parameter2, Parameter3, Parameter4)
SYSTEM_SERVICE_EXCEPTION
20x20_grey_minus.pngCAUSE
This issue occurs because of an error in the Microsoft IEEE 1394 driver stack, in which the buffer that is allocated to the driver stack does not initialize correctly.
20x20_grey_minus.pngRESOLUTION
Hotfix information A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing the problem described in this article. This hotfix might receive additional testing. Therefore, if you are not severely affected by this problem, we recommend that you wait for the next software update that contains this hotfix.
If the hotfix is available for download, there is a "Hotfix download available" section at the top of this Knowledge Base article. If this section does not appear, contact Microsoft Customer Service and Support to obtain the hotfix.
Note If additional issues occur or if any troubleshooting is required, you might have to create a separate service request. The usual support costs will apply to additional support questions and issues that do not qualify for this specific hotfix. For a complete list of Microsoft Customer Service and Support telephone numbers or to create a separate service request, visit the following Microsoft Web site:Note The "Hotfix download available" form displays the languages for which the hotfix is available. If you do not see your language, it is because a hotfix is not available for that language.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1538952
please upload dmp files and has memtest passed for 8 times in a row? and try reinstall and opdate bios
I don't know where the dmp files are, my Minidump folder in %SystemRoot% is empty.
When I did the memtest, each memory stick passed like 5 times in a row and I thought that was enough. Should I really make sure both passed at least 8 times?
I actually have updated my BIOS twice, first one was when I first built my PC back in February, and the second one was in October last year and I believe it was the latest version of the BIOS.
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539070
Microsoft Support
Thanks a lot. I installed the hotfix, but I don't know whether it really works or not because I don't even know when my PC was gonna crash, it happened randomly. Hopefully it works and I'll never see that BSOD in the future.
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539097
check if it even saves the dmp files and yes i recomend just letting it pass 8 times but please put all the memory together
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539115
How do I check that?
I did all both ways, separate sticks and both sticks together, and all passed 5 times. But I'll give it another try and let it pass 8 times.
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539133
sorry its dutch but here are the steps start - right click computer - properties - left side advanced settings - start up and advance settings - you will see
http://puu.sh/6UybS.jpg
-Adolf Hitler
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539154
Ok, under the System Failure, both checkboxes are checked, and under Write debugging information it says Kernel memory dump. Small dump recovery : %SystemRoot%\Minidump
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539168
then go to that path and see if anything is there (oh and make sure you are able to see hidden files)
-Adolf Hitler
https://linustechtips.com/topic/115120-bsod-0x3b-please-help/#findComment-1539173
